Survey123 Quarterly Annual Report
291
08-09-2023 10:49 AM
EddyClark
Can anyone point me in the right direction on how to create a quarterly/annual report?
If I had a Survey123 form with some fields, say "date range".  I'd like to be able to report all features collected within that date range and export the report.
RobertAnderson3
MVP Regular Contributor
If you're looking for a report that's automatically generated quarterly you could look at the video here: Re: Survey123 Tricks of the Trade (Live): Automate... - Page 2 - Esri Community
At around 31 minutes in Ismael gives a nice little trick for setting up the WHERE clause in the Survey123 report webhook action. This can also show you how to set up the filter on the Survey123 website to export it manually if you prefer. You would need to set up the report template first as well to make this work.
