I am new to Power Automate, so I apologize if this is very easy, but I couldn't find a reference.
We have a feature layer that is being used within a Workforce application. After the work is completed, there are actions another department needs to take on certain types of work (i.e, a meter replacement needs to be sent on while a meter check is done and does not require an email sent). We would like to send an email to the department filtered by assignment type. I have been trying to set the Trigger Conditions in the flow to filter for those assignment types, but haven't been able to get it to work. Is this a possibility? If so... could someone help me with the proper syntax to configure this.
Thank you for any advice you may have!
Hi Kim_Graham,
I think you would use the "When a record is updated in a feature layer" and then the "Fetch updates, changes, or deletions from feature layer" action on the assignments feature layer and then have a condition to check the assignment type e.g.
Can you explain how/what order you added the triggers to that flow? I am also looking to automate an email notification when an Assignments layer attribute is updated to Completed. When adding the triggers in your screen capture, dynamic content doesn't automatically pop-up for me when adding the Fetch updates, changes, or deletions from feature layer trigger.
Hi SarahRijneke,
That looks like the ArcGIS connection being used is not right. If you click on the "..." is the ArcGIS connection being used the same for both the trigger and action?
e.g.
For me it's the second one down in both the trigger and action.
Thank you! I was able to select the correct connection from the drop down list. The flow isn't working though:
Hi, looks like the feature layer ID and changes URL parameters need to be set e.g.
Hi, I am creating this same workflow in power automate but i receive an error message.
Thanks - that worked! Any tips on blogs/tutorials to get up to speed with setting up ArcGIS flows? I was able to create a very similar flow using a Survey123 trigger without any issue but definitely would not have been able to figure this one out myself.
I'm seeing one more problem now that I can't seem to figure out. The condition that I have is set up the exact same way for another flow using Survey123 (both schemas are the same since they both use workforce assignment feature classes) and that one works no problem. This flow only seems to work once an edit is made AFTER the status field has been set to completed. i.e. when I change the status field from unassigned to completed in the Field Maps app I do not receive an email. When I delete the completed point from the feature layer, I receive an email. How do I get it to trigger when a field worker updates the status to completed?
Hi Sarah.... I keep trying to leave a reply but it posts and disappears....weird. Anyway I was not able to get this to work when trying to filter based on a single attribute type. There is a post from June called "Only retrieve updates from one field" that says this is not actually possible to do using the ArcGIS Connector.
Has there been any more movement on the ability to get this to work on a single attribute? I can get this flow to work, but it runs with any update on the entire feature layer, not just the attribute in the Condition portion.
