I had a few Power Automate flows setup six months ago and since September they stopped working. I've try to re created from scratch using a template (Track when a record is created in a feature layer in ArcGIS Online) and I keep getting this error message:
My Connection to AGOL is valid
what am I doing wrong????
Thanks!
Could not retrieve values. The dynamic invocation request failed with error: {
"error": {
"code": 400,
"source": "unitedstates-002.azure-apim.net",
"clientRequestId": "39bcdc27-e61b-40d6-a295-1302a78c2c3b",
"message": "The response is not in a JSON format.",
"innerError": "Cannot read properties of undefined (reading 'forEach')"
This issue has been fixed by ESRI (I received an email from ESRI tech support). Everything is working fine for me once again.
Thank you for your question.
We are working on identifying and fixing this issue. The drop-down should be populated with layers owned by the user.
To help us identify the issue, could you please:
Confirm if the same issue happens in the dropdown in Fetch updates, changes, or deletions from feature layer.
Confirm if you face the same issue with the dropdown when using Get data from feature layer action:
As a workaround, could you confirm if you can do the following:
Please let us know if the workaround works while we try to address the underlying issue.
@PavelJ , thanks for getting back to me.
1) issue is the same for When a Record is Created and when a record is updated an in Fetch updates, changes, or deletions from feature layer.
2) drop down works for Get Data from Feature layer
3) following your workaround, the webhook was created on the HFL and the flow ran success.
@DominicRoberge2 - Thank you for confirming that this has been resolved. Please let me or @PavelJ know if you have any other issues.
