Being able to rename an ArcGIS Connections
394
12-04-2023 02:44 PM
Status: Open
DominicRoberge2
Occasional Contributor III
It would be nice to be able to rename an ArcGIS Connection similar to the SQL Server Connection (the Display Name option).
Our use case is that we have lots of HFL owned by our PSA, so I have to create flows connecting using the PSA credentials and some flows using my own HFL items.  Being able to identify which connections belong to which accounts would be helpful when comes time to "refresh" the connections to avoid a token issue.
Thanks!
1 Comment
AnthonyLatini
Hi @DominicRoberge2. Thank you for adding this idea. This is an enhancement that is controlled by Microsoft and has been an ask by our group as well.
As a note - to remain logged in, a flow should run at least once within the given token timeout period. As long as you have a flow that makes use of the connection, then it will stay active. I keep a "dummy" flow running with "Get data from feature layer" that checks every 10 days to pull data from a test layer I created.
