Exporting polygon to CAD becomes a polyline
5742
03-02-2015 10:20 PM
SiyangTeo
Hi, I tried exporting a polygon feature class as a CAD file using the Tool "Export to CAD". I have added the CAD fields before this.
However, the output seems to convert them into polylines (see attached). Even though the shape is clearly polygon, its entity registers it as LWPolyline. I suspect that as a result, the "FillColor" field did not get embedded in the CAD file after conversion (that's the main reason why I need it to be a polygon).
I am using ArcGIS 10.2.2.
Thanks!
SachinKanaujia
Will it be possible for you to share the shapefile. I tried it on a Polygon shapefile and it gives me both polygon
SiyangTeo
Hi Sachin,
Please find the download links to the data (dummy ones) below.
Shapefile of polygon
https://dl.dropboxusercontent.com/u/5087820/Shapefile.zip
converted DWG file
https://dl.dropboxusercontent.com/u/5087820/test1.DWG
Actually I just found out that other CADs I have from surveyors also have their Polygons drawn as Polylines. Hence I guess this is normal?
How do I input a fill colour into the polygons then?
Thank you.
