ArcGIS for AutoCAD
Browse ArcGIS for AutoCAD
Sort/Filter :
Latest Activity
Sort/Filter :
POST
Is ArcGIS for AutoCAD needed by Civil3D to view ESRI map services in Civil3D?  Our CAD users don't need to edit GIS d...
RandyKreuziger1
by RandyKreuziger1 Frequent Contributor
in ArcGIS for AutoCAD Questions Last Updated 12-08-2025
0 1
POST
Hello, I used Add Data by URL in the ArcGIS tab of AutoCAD 2026.In the Model tab, from the Esri Contents panel, I use...
BoolieOdell
by BoolieOdell New Contributor
in ArcGIS for AutoCAD Questions Last Updated 11-26-2025
0 1
BLOG
This release also expands the support of CAD data as GIS content by adding support for hatch entities as polygons and...
DanWade
by DanWade Esri Contributor Esri Contributor
in ArcGIS for AutoCAD Blog Last Updated 11-06-2025
3 0
IDEA
 Add/remove multiple WFLs at once.Option to ignore symbology groups on load.Auto-remove associated CAD layers when WF...
rahulkirola
by rahulkirola Emerging Contributor
in ArcGIS for AutoCAD Ideas Last Updated 12-01-2025
0 4
IDEA
Could ArcGIS for AutoCAD be developed/ported to macOS? Or are there still any AutoCAD API limitations preventing this...
marcarch
by marcarch Emerging Contributor
in ArcGIS for AutoCAD Ideas Last Updated 09-15-2025
0 1
POST
It seems allow me to add tiled imagery layer to a drawing, but its' not loading anything. Works ok for dynamic imager...
BrandonGuo
by BrandonGuo Frequent Contributor
in ArcGIS for AutoCAD Questions Last Updated 09-11-2025
0 5
488
BLOG
Explore a packed agenda for CAD/BIM integrations at the 2025 Esri User Conference, incuding sessions on ArcGIS for Au...
MichaelDavidsonPM
by MichaelDavidsonPM Esri Contributor Esri Contributor
in ArcGIS for AutoCAD Blog Last Updated 06-19-2025
1 0
POST
I have seen the ArcGIS plugin for AutoCAD pull in a line feature layer, create a version, make edits, then sync back ...
DrewDowling
by DrewDowling Frequent Contributor
in ArcGIS for AutoCAD Questions Last Updated 06-19-2025
0 1
IDEA
It would be great to be able to leverage C3D labels (general line / curve label styles for lines / point label styles...
DevinB
by DevinB Emerging Contributor
in ArcGIS for AutoCAD Ideas Last Updated 05-20-2025
0 0
IDEA
Hi there,We had a user that added a feature service with multiple sublayers. These all added as individual Web Featur...
Marc_Graham
by Marc_Graham Frequent Contributor
in ArcGIS for AutoCAD Ideas Last Updated 11-10-2025
0 4
POST
Hi there,One of our CAD users was creating a drawing with several ArcGIS layers showing underground services from Arc...
Marc_Graham
0 1
IDEA
It would be great if we could have a checkbox when loading web feature layers to ignore the symbology set to prevent ...
DerekBannon22
by DerekBannon22 Emerging Contributor
in ArcGIS for AutoCAD Ideas Last Updated 2 weeks ago
0 4
POST
Hello everyone, One issue we've consistently run into is that synchronizations and loading of web feature layers slow...
DerekBannon22
in ArcGIS for AutoCAD Questions Last Updated 10-20-2025
0 3
BLOG
Updates2025-11-06: The latest release of ArcGIS for AutoCAD resolves this issue.2025-06-04: The latest beta of ArcGIS...
MichaelDavidsonPM
in ArcGIS for AutoCAD Blog Last Updated 04-16-2025
1 0
IDEA
When you convert a dwg to a featureclass in ArcGIS Pro there are a few attributes that get created, such as layername...
Marc_Graham
2 1
