Track time spent at an asset
956
02-14-2023 10:35 AM
ArianaToth
Is it possible to populate an attribute field with time data taken from a tracking layer? Specifically, can you populate a hydrant flush time field by measuring the time spent standing next to the hydrant?
--Ariana
Tags (1)
JustinColville
Hello Ariana,
This could be accomplished using the ArcGIS API for Python.  Our team has a sample Notebook in our Scripts repo called Find Dwell Times at Polygons that could be a starting point, replacing the polygon layer by buffering your hydrants.  The dwell start/end time output is written to the console, but could be used to calculate a duration and update an attribute field.
JustinColville
Hello Ariana,
