Survey Callback to ArcGIS Fieldmaps stopped working.
995
03-30-2022 12:27 AM
ZoevdbAT
My Survey URL callback stopped working. I guess it has something to do with an update in either ArcGIS Online, Fieldmap app or Survey123 app.
arcgis-survey123://?itemID=XXX&field:boomid={BOOMID}&field:inspecteur={created_user}&center={LAT},{LON}&callback=https://fieldmaps.arcgis.app/?referenceContext=open%26itemID=XXX&portalURL=https%3A%2F%2FDongen.maps...
It used to redirect back to Fieldmaps after submitting a survey. Now it opens my browser with the suggestion to download Fieldmaps on my device.
How can I fix this?
by Anonymous User
Not applicable
On Android can you go to Settings->Apps->Field Maps? There should be a setting called "Open by default". Tap that. Check if the "Open supported links" toggle is checked and that the link is verified.
by Anonymous User
Not applicable
ZoevdbAT
Thanks Aaron, that did the trick!
