Search tab does not work on any of my web maps
952
8
07-21-2022 05:22 AM
dalvarez
The address/ asset search tab does not work on web app when open on field maps app. It does work on the web map on GIS online.
I have reviewed the settings on the web map, updated the application on the Ipads, and reviewed setting on the Ipad for the application but the issue persists.
ElizabethLorenaRodriguez
Hi!
Does the address tab work in other web maps? Or It only happens with a particular web map?
dalvarez
No, it doesn't work on any of the web maps on field maps or collector.
Are you working on ArcGIS Online? or Portal for ArcGIS?
dalvarez
ArcGIS online
Try this out:
Go to theWeb map and make sure you have allowed search by layer.
dalvarez
Thanks, I tried this , but it didn't make a difference unfortunately. I saw this comment some time ago, I will pass it along to the person that manages enterprise. I wish I could give him more information on what he would need to do. If someone knows more about it, please let me know.
FionaRenton1
Occasional Contributor II
I have had this setting change on the web map (ArcGIS Enterprise 9.1) and I'm not sure why. I set up search for some fields in the map viewer and search by address, then somehow it got changed to be unchecked in the settings. I am not sure if this is because I am using  map viewer classic (the new  map viewer still does not support related tables). I can only have search by feature or search by address it seems.
See the note in the documentation for enable search
Set map options for apps—ArcGIS Online Help | Documentation
dalvarez
Thanks for the resource info
