is there an expression to differentiate SELECT vs ADD in arcade expression?
2481
09-05-2023 09:56 AM
WilsonLee
in Field Maps Arcade Expression, how can I differentiate between "selecting an existing point" and "adding a new point" within an Arcade expression.
I'm trying to apply a  different code based on the action selected by a user (SELECT vs ADD) from a same layer.
currently, i have setup 2 layers in field maps for "Updating" and "adding a new point", but would like to combine them and make it more convenient for user.
thanks,
Wilson
Tags (3)
JustinReynolds
@WilsonLee
I believe what you are looking for is the edit context/edit type.  It is a profile variable found in the Form Calculation and Form Constraint Arcade Profiles
https://developers.arcgis.com/arcade/profiles/form-calculation/
https://developers.arcgis.com/arcade/profiles/form-constraint/
Your Add is INSERT and your select is UPDATE.
// Example usage of $editcontext.editType
if ($editcontext.editType == 'UPDATE') {
    if (!IsEmpty($originalFeature)) {
        var oSelf = $originalFeature.rsrc_previous_feature_info;
        var oServiceNumber = $originalFeature.service_number;
        if (oServiceNumber == serviceNumber) {return oSelf};
- Justin Reynolds, PE
JustinReynolds
@WilsonLee
WilsonLee
Thanks Justin!!! let me try to update my codes🙏
WilsonLee
THANKS again! it works!!
