Get a value from a layer (with joined table) in a web map
1059
07-24-2023 12:28 PM
WilsonLee
Hi, I am creating a form for a layer. In 1 field, I want to get get a value from another layer (with joined table, it's map service published from a ArcGIS Server) in a same web map.
var treeGrid = FeatureSetByName($map,"GROUNDS.SEQ")
var result = Intersects($feature, treeGrid)
return Upper(first(result)."GROUNDS.TI2_MAX_SEQ.SEQ")
Test execution error: Unexpected text literal.. Verify test data.
(It was fine if i am getting a value from another layer without joined table)
Does Field Maps support accessing values from a layer with joined table in Arcade? is my code correct for this?
thanks a lot!!!
W
DougBrowning
Your 3rd line there should not have the field name in quotes - that makes it a string.  Also when sending a list of fields to FeatureSet you need to send a list in line 1.  Also I do not see the layer name in line 1.
Then this part TI2_MAX_SEQ I have no idea what that is.  The format should be record.fieldname
Try this
var treeGrid = FeatureSetByName($map, "NameOfLayerInMap", ["GROUNDS.SEQ"])
return Upper(first(result).GROUNDS.SEQ)
Hard to tell since I am not sure what you are trying to go.
Hope that helps
WilsonLee
thanks Doug!
i got the idea, thanks for your help
