Field Maps URL app integration center on workorder
451
05-02-2023 11:46 PM
by Anonymous User
Not applicable
The scenario is:
  • A web application that contains details about a WorkOrder needs to launch FieldMaps and zoom to the location of the WorkOrder on a map
  • The two applications need to be linked by using the WorkOrderID
  • We have already published a read-only WorkOrder feature class and added it to the webmap that FieldMaps will use,
  • Was hoping to use the search parameter to link to the correct WorkOrder in the map but not really sure of the syntax. I think its a bit more complex than just passing the webmap ID and the WorkOrderID to find. I have looked through the posts here and cannot really find an example that best approximates what we want to do
thanks Len
