Field Maps - MDM
857
01-18-2023 09:18 AM
mbowser13
I am trying to push a location profile property to multiple devices through MobileIron. I have created a plist with the location profile properties but I receive a response from MobileIron that the file is not valid. Any thoughts on where i've gone wrong with the plist?
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN"
"http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
	<key>name</key>
	<string>RTK Profile</string>
	<key>mapCoordinateSystem</key>
	<integer>3857</integer>
	<key>gnssCoordinateSystem</key>
	<integer>6318</integer>
	<key>horizontalDatumTransformationName</key>
	<string>~WGS_1984_(ITRF08)_To_NAD_1983_2011</string>
</dict>
</plist>
ChrisDunn1
Hi @mbowser13,
For the location profile MDM setting, the parameter only takes a single key/value pair.
The key is locationProfiles.
In your case the parameter would be the following string:
[ { "name":"RTK Profile", "mapCoordinateSystem":3857, "gnssCoordinateSystem": 6318, "horizontalDatumTransformationName": "~WGS_1984_(ITRF08)_To_NAD_1983_2011" } ]
I hope that helps!
Chris
