field map designer: related records not currently supported on mobile
15793
22
06-28-2023 11:24 AM
L77
My coworker is getting this error:
Related Records not currently supported on mobile.
It is my role to help her troubleshoot when she has issues. How do I know if there is an issue with her data or the field map designer tool?
In field maps she can see the related table and can edit it and the edits are syncing to her online map.
But she can't view or modify the related table in the field map designer tool. She said that it was working this morning.
I had her create a new map that only had the point layer with the related table and open it in field maps designer and it had the same error.
I'm not sure what to try next. I told her that maybe there is an issue with the tool and to wait an hour and check again then to see if it is resolved.
If you have any troubleshooting suggestions please let me know.
Also, does anyone know if there is a place where I can read about current bugs with field maps designer or field maps mobile app? We are using these tools daily now so it would be nice to look for bugs so we will know if there is something wrong with our data or something wrong with our tools.
Thank you!
KristalWalsh
@DougBrowning your input on this topic is very helpful. I think I mentioned I have been taking the traditional route with 1:1 and 1:many relates in a file geodatabase published to AGO and then forms designed in Field Maps, but having alot of errors and back and forth, also running into the fact it wouldn't handle feature to feature relates. So I'll be looking more into Survey 123 since I have only 5-6 tables. Hopefully it will be easier! Thank you!
Kristal Walsh, Florida Fish and Wildlife
Office of Conservation Planning
tiztrain
Does Field Maps work with multiple relationships? If it does, do you just need to create a GUID field for every table that has the cardinality of 'Many'?
mikaël
I can add or edit related records when I set up the form inside map viewer, but I can't add (new) related records when using Field Maps (with some mobile device). I can edit existing ones though.
Is that the takeaway here?
@DougBrowning ?
Thanks!
Edit:
Never mind, got my answer here:
Unable to use related record elements
Related record elements can be added to the form using the form builder inMap Viewer, however, they are not currently supported inArcGIS Field Maps. While related record elements added to the form will appear inField Maps Designer, they cannot be formatted and will be hidden from the form in theField Mapsmobile app.
If you delete a related record element from the form inField Maps Designer, you cannot add it back to the form. You can only add related record elements to the form inMap Viewer.
Second edit 🙃:
A workaround is to add your feature in Field Maps and send. Then click again on that feature, and then click on related records and then you can add how many related features you need to. It's just not as streamlined, but I guess it works!
