Calculated Value Override / Overwrite?
3537
04-30-2023 09:28 PM
HenryKo2
Hi, I'm using Field Maps in ArcGIS Online. I have some fields that are calculated dynamically with arcade expressions. This is all working fine.
However, is there a way to allow users to override/overwrite the calculated values?
It appears once the calculations are done, the fields are no longer editable. I'd like to allow users to override/overwrite/make corrections to the calculated fields.
2 Solutions
DougBrowning
MVP Esteemed Contributor
In 123 we do the 3 field trick.  Have one field for the user input, one field that is the calculation and a 3rd field that picks which one.   If user field has a value use it, if not use the calculated.  In 123 you can have the two temp fields not stored but I do not think you can in Field Maps.  You could hide the temp fields in your map though.
AlixVezina
ChristopherCounsell
MVP Frequent Contributor
This is not directly possible and appears to be a limitation. Fields with calculations can't be edited by fieldworkers.
Some users have discussed having an additional field that users could update to re-calculate the field but this is a bit redundant, so not a great workaround:
https://community.esri.com/t5/arcgis-field-maps-questions/new-field-maps-calculated-expressions-and/...
DougBrowning
HenryKo2
Thanks. Good trick, I got it working, although the UI/UX on the Field Maps app is not that nice, but that would do for now.
AlixVezina
Please also see this post for proposed workaround: How to override values for fields with calculated expressions (esri.com)
