Adding a checkbox to Field Maps form
548
03-10-2026 10:31 AM
doronwen
I'd like to add a checkbox to field to a Field Maps form so users can pick from a list of options and in turn, the options they pick will get populated in a text field with comma separating their selections.
Example:
Filed Name: Hazards
Options to pick from: Steep Slope, Flooded, Utilities, No Parking, Extreme Cold.
In the Filed Maps form, a user checks "Steep Slope" and "Utilities".
I'd like those two selections to populate the Hazards field in the feature class with a comma separating the two options: Steep Slope, Utilities.
Is there a way to add a checkbox field in Field Maps?
Tags (1)
RhettZufelt
MVP Notable Contributor
I voted up your idea for this, but, since there are other ideas requesting the same thing since at least early 2021, I wouldn't get my hopes up.
Might help to Kudo/comment on the posts, though it doesn't seem to get much traction.
Allow Select Multiple Questions in Field Maps
Multiple choice option in Field Maps
Workarounds appear to be use Survey 123 for this.
R_
RhettZufelt
R_
doronwen
@RhettZufelt Thank you for sharing. I'd remove my post if I had the option to.
