Field Maps Tasks: Shift-based (06:00–06:00) filtering using esritask_duedate
668
03-04-2026 12:21 AM
ZentraleTechnik
Hi everyone,
I’m working with Tasks in ArcGIS Field Maps and I’m trying to implement a shift-based time filter.
Goal / Requirement
We run operational shifts from 06:00 today to 06:00 the next day. We need the task list to be consistent across midnight, e.g.:
  • A user logs in at 23:00 and sees the tasks for the current shift (06:00 → 06:00).
The same user logs in again at 02:00 (after midnight) and should still see the same shift tasks, not a new set.
The task layer contains the standard due date field esritask_duedate, which is filled and used as the “deadline”.
What works (but not sufficient)
A basic filter like the following is valid and works logically for “calendar day”, but it breaks after midnight because the day changes:
esritask_duedate BETWEEN (CURRENT_DATE + 0.2083333333) AND (CURRENT_DATE + 1.2083333333)
(0.2083333333 = 5/24, intended to represent “06:00 local” depending on time zone setup.)
Problem: when the calendar day changes at midnight, users logging in between 00:00–06:00 see the next day’s window, and tasks from the ongoing shift are no longer included.
Attempted solution (dynamic switch “before/after 06:00”)
To keep the same shift across midnight, I tried a dynamic “switch” logic:
  • If current time is before 06:00, filter yesterday 06:00 → today 06:00
Else filter today 06:00 → tomorrow 06:00
  (CURRENT_TIMESTAMP <  (CURRENT_DATE + 0.2083333333) AND
   esritask_duedate BETWEEN ((CURRENT_DATE - 1) + 0.2083333333) AND (CURRENT_DATE + 0.2083333333))
  OR
  (CURRENT_TIMESTAMP >= (CURRENT_DATE + 0.2083333333) AND
   esritask_duedate BETWEEN (CURRENT_DATE + 0.2083333333) AND (CURRENT_DATE + 1.2083333333))
Issue
This expression appears valid in Field Maps Designer, but when opening the map in theField Maps mobile app, Tasks fail to load and the app shows:
“Tasks couldn’t be loaded. Contact the map author for more information.”
I also tested using EXTRACT(HOUR FROM CURRENT_TIMESTAMP) earlier, but Field Maps mobile did not support it either (same outcome).
Question
  1. Is there a Field Maps mobile limitation regarding dynamic SQL functions (CURRENT_TIMESTAMP, EXTRACT, etc.) in Tasks filters / to-do lists?
  2. Is there a recommended approach to implement a 06:00–06:00 shift window using only esritask_duedate that works reliably in Field Maps mobile?
  3. If this is not supported via SQL in Field Maps mobile, what is the best practice workaround?e.g., precomputing a shift anchor field (like shift_date) on insert/update (server-side or via automation), and filtering on that instead?
Any hints, confirmed limitations, or working examples would be greatly appreciated.
Thanks in advance!
LaurentSavoy1
I’m facing the exact same issues, but only in Field Maps. I’m currently limited by the available date-filtering (temporal filtering) functions—similar to what QFIELD supports (see link above). I can’t create a date filter that returns only the previous shift, which would allow my operators to filter and review what was completed during the prior shift.
https://docs.qfield.org/how-to/advanced-how-tos/temporal-filtering/
I’ll keep an eye on what people post here as a solution.
MarcMuehleisen89
When testing this, i found out that Date Arithmetic is not supported on the Client although the expression seems to be valid in FieldMaps Designer.
I tested expressions such as CURRENT_DATE + 1 = CURRENT_DATE + 1 which compared to 1=1 delivers no results.
