Issue Summary – ArcGIS Field Maps (Online) – High Latency Due to Repeated Recalculation of Arcade Expressions
1500
11-13-2025 10:40 AM
sanderllandawillindecosta
Hello Esri team,
I am reporting a performance issue in ArcGIS Field Maps related to calculated fields that use Arcade expressions referencing other layers in the map (e.g., FeatureSetByName, Intersects, Nearest, Filter, etc.). The problem occurs only when working online.
In offline mode, all calculations run instantly and the form behaves smoothly, even with complex dependencies. However, in online mode, Field Maps appears to recalculate every Arcade expression each time any field is edited, even when the edited field has no relation to those expressions. Every recalculation triggers new queries to the hosted feature service, causing noticeable and cumulative delays during data entry.
The latency is often greater than 5 seconds for each field edited, and in some cases even longer. Because this happens at every input step, filling long or complex forms becomes impractical. The user must wait for all expressions to finish re-evaluating before continuing. In workflows involving many questions, this creates a chain of delays that severely impacts productivity. While going offline resolves the issue completely, some teams cannot work offline due to corporate policy or real-time data needs.
This behavior suggests that Field Maps might:
  1. Be recalculating all expressions instead of only those affected by the modified field;
  2. Be running repeated, identical queries to the server without caching results;
  3. Be processing visibility, required logic, and calculation logic multiple times for the same expression.
Impact:
The issue affects field operations that rely on multi-layer lookups—such as environmental, geotechnical, asset inspection, and infrastructure workflows. For extensive surveys, the cumulative wait time becomes unviable for field use.
Expected / improved behavior:
  • Recalculate only expressions dependent on the changed field;
  • Cache FeatureSet queries during the editing session to avoid repeated server calls;
  • Provide an option for “calculate on submit” for heavy expressions;
  • Align online performance with the much faster offline behavior.
I can supply sample Arcade expressions, videos of the latency, screenshots, and a reproducible test environment upon request.
Thank you for reviewing this issue. Improving the recalculation logic would significantly enhance Field Maps performance for advanced forms involving spatial queries and calculated fields.
2 Comments
DavidSolari
If these are attribute rules added to the feature classes and table, you can use the new Triggering Fields option to only run rules for the appropriate fields.
If you're building your rules in the form view (or you're stuck on an older version of Pro) you can put a guard at the start of the expression to return early if the relevant fields haven't changed, like:
if ($feature.field1 == $originalfeature.field1) return
That said, a "calculate on submit" option would be handy for forms with complex rules. I doubt there'll be an option for online maps to only use cached values as the results are less predictable than offline maps, but deferring calculations doesn't have that problem.
LindsayRaabe_FPCWA
This is clearly a different request (and I agree, a valid concern). Here's an idea thats loosely related about the offline calculation of fields - Improve performance of Arcade calculations when OF... - Esri Community Perhaps there's some overlap in them.
