ArcGIS Field Maps Ideas
Other Boards in This Place
Latest Activity (506 Idea Submissions)
Sort/Filter :
Open
Enable snapping when using the Measure Distance Tool in Field Maps.Without snapping, the measure distance tool is gue...
Debert
by Debert Frequent Contributor
in ArcGIS Field Maps Ideas Last Updated 3 weeks ago
3 2
Open
Currently the GPS/GNSS standard metadata fields are only those that come from the GGA string.  For serious surveyors ...
spicergroup
by spicergroup Occasional Contributor
in ArcGIS Field Maps Ideas Last Updated 05-08-2025
4 0
Open
I am requesting the ability to copy or duplicate forms in Field Maps Designer—either by feature layer or hosted featu...
Debert
3 2
Open
Hi there,We are looking for a way to make our layer groups in our layer list collapsed by default for a better/cleane...
Derek_Eamer
by Derek_Eamer Occasional Contributor
in ArcGIS Field Maps Ideas Last Updated 04-25-2025
4 2
Open
Filter the layers present in a web map based on the map extent, allowing the sharing of only that specific extent of ...
LAG155
by LAG155 Occasional Contributor
in ArcGIS Field Maps Ideas Last Updated 03-10-2025
4 0
Open
In Field Maps allow the users to Change the Background when taking a section offline for Offline Maps
LianneStewart
by LianneStewart Occasional Contributor
in ArcGIS Field Maps Ideas Last Updated 02-14-2025
0 0
Open
Ability to add custom "favorite" filters so users are not resetting to the default filters upon login in Field MapsAb...
LianneStewart
in ArcGIS Field Maps Ideas Last Updated 02-13-2025
1 0
Open
Copy Attributes in Field Maps Defaults to Copy Feature Location, not GPS even when the GPS location in turned on. The...
LianneStewart
0 0
Open
Add the ability to select multiple records in the map in Field Maps by enabling a Lasso selection for the Map.
LianneStewart
in ArcGIS Field Maps Ideas Last Updated 03-11-2025
4 1
Open
Popup Titles Need Wrap Text or Resize Pane OptionUse Case:- We use FieldMaps for tracking treatments on invasive plan...
ChrisRoot
by ChrisRoot Occasional Contributor
in ArcGIS Field Maps Ideas Last Updated 02-28-2025
9 7
9
7
Open
A key need in the mining industry is the ability to perform geological map editing directly in the field. Field Maps ...
BlendaRodriguesCarvalho
by BlendaRodriguesCarvalho Occasional Contributor
in ArcGIS Field Maps Ideas Last Updated 12-06-2024
3 0
Open
Configuring maps in the designer offers a "Collecting new features" option that changes how the app behaves when a ne...
DavidSolari
by DavidSolari MVP Regular Contributor MVP Regular Contributor
in ArcGIS Field Maps Ideas Last Updated 11-14-2024
3 3
Open
We recently became aware that all of our maps in our organisation are automatically shared to Field Maps mobile by de...
HeatherBell
by HeatherBell Frequent Contributor
in ArcGIS Field Maps Ideas Last Updated 11-19-2024
12 3
12
Open
Web maps and their data layers support a wide variety of use cases, hence they need to support configuration and sett...
PeterKnoop
by PeterKnoop MVP Regular Contributor MVP Regular Contributor
in ArcGIS Field Maps Ideas Last Updated 09-10-2024
11 0
11
Open
I'd like to see an option to enable/disable a tone or sound while using the compass tool to navigate to a known point...
fjramos
by fjramos Frequent Contributor
in ArcGIS Field Maps Ideas Last Updated 04-17-2025
8 2
8
313 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
