ArcGIS Field Maps Ideas
Other Boards in This Place
Latest Activity (372 Idea Submissions)
Sort/Filter :
Open
I would love to see non-schema "Note" fields in Field Maps. Basically a dummy field that allows custom expressions th...
KPyne
by KPyne Occasional Contributor
in ArcGIS Field Maps Ideas Last Updated 10-04-2023
6 3
6
Open
Similar to how you can define Arcade expressions to indicate if a field should be visible or is required, I would lik...
NathanHeickLACSD
by NathanHeickLACSD Occasional Contributor III
in ArcGIS Field Maps Ideas Last Updated 08-30-2023
2 0
Open
I help different forest managers, and each of them are in different AGOL organizations, with setting up form for use ...
JensKolstad
by JensKolstad New Contributor III
in ArcGIS Field Maps Ideas Last Updated 08-21-2023
2 4
Open
At the moment you cannot edit or add records to a hosted table in Field Maps unless it is related to a feature layer....
RichardHowe
by RichardHowe Occasional Contributor II
in ArcGIS Field Maps Ideas Last Updated 09-24-2023
18 3
18
Open
I have a Status question for a polygon layer that has domains like 'New Request', 'In Progress', 'Send to Review', 'S...
PaviEsri
by PaviEsri New Contributor II
in ArcGIS Field Maps Ideas Last Updated 08-16-2023
2 0
Open
Currently, in Field Maps Designer (Form configuration), the Input type options for integer fields are "Number - Integ...
David_Kimball
by David_Kimball New Contributor II
in ArcGIS Field Maps Ideas Last Updated yesterday
4 2
Open
We should be able to toggle whether "Recent Value" suggestions are enabled at a question level in Field Maps Smart Fo...
jtmouw_NCDOT
by jtmouw_NCDOT New Contributor III
in ArcGIS Field Maps Ideas Last Updated 06-29-2023
1 0
Open
It would be very helpful if we had the ability to edit the domains (or lists) of fields that have a domain specific t...
TomGill23
by TomGill23 New Contributor II
in ArcGIS Field Maps Ideas Last Updated 06-15-2023
6 1
6
Open
Please add the capability to use Arcade for the validation of field content.  For example a valid permit number needs...
DanHuerter2
by DanHuerter2 New Contributor II
in ArcGIS Field Maps Ideas Last Updated 06-21-2023
11 1
11
Open
When configuring a form in Map Viewer, when a required field is left off and the OK button is clicked, the form is cl...
KenBuja
by KenBuja MVP Esteemed Contributor MVP Esteemed Contributor
in ArcGIS Field Maps Ideas Last Updated 05-04-2023
9 1
9
Open
Please bring this posibillity to FieldMaps:  https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformsappea...
RobertHofstede
by RobertHofstede New Contributor II
in ArcGIS Field Maps Ideas Last Updated 04-20-2023
7 0
7
Open
Currently there is an option to decide if each form group is collapsed by default in the Field Maps mobile app by dis...
ChristianBPedersen
by ChristianBPedersen Occasional Contributor II
in ArcGIS Field Maps Ideas Last Updated 04-18-2023
2 0
Open
Over the next few weeks......my organization will be utilizing ArcGIS Field Maps to perform a large collection activi...
Anonymous User
by Anonymous User Not applicable
in ArcGIS Field Maps Ideas Last Updated 04-27-2023
3 3
Open
There is an option missing to be able to show grouped classes and their headings of a given feature class when a coll...
ChristianBPedersen
in ArcGIS Field Maps Ideas Last Updated 04-14-2023
1 0
Open
No ArcGIS Dashboards, permitir a integração entre duas colunas de uma tabela de atributos. Por exemplo: Uma equipe de...
GeoprocessamentoNovaLima
by GeoprocessamentoNovaLima New Contributor II
in ArcGIS Field Maps Ideas Last Updated 04-11-2023
1 0
259 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
