ArcGIS Field Maps Ideas
Other Boards in This Place
Latest Activity (626 Idea Submissions)
Sort/Filter :
Open
Idea: Update the tip in the "Manage offline areas" panel to add this note from the documentation: "The update action ...
HollyTorpey_LSA
by HollyTorpey_LSA Frequent Contributor
in ArcGIS Field Maps Ideas Last Updated Friday
0 0
Open
They are used to having a +/- button on the map layer to zoom in and zoom out on the map with a pre-defined zoom rang...
Etiennenoumen
by Etiennenoumen Emerging Contributor
in ArcGIS Field Maps Ideas Last Updated Monday
2 1
Open
We have a few clients that use complex dynamic geofences, or post-processing FME, or just asking them to remember to ...
Scott_Sambell
by Scott_Sambell Frequent Contributor
in ArcGIS Field Maps Ideas Last Updated a week ago
3 0
Open
The Field Maps app on mobile phones is super useful. In the organisation I work for, I would really like to have a de...
msf-jordan-gisbrusselsmsforg
by msf-jordan-gisbrusselsmsforg Emerging Contributor
5 2
Open
With the new capability for viewing GeoPDFs in Field Maps (thank you!), users will likely view multiple GeoPDFs in Fi...
LinzMess
by LinzMess Occasional Contributor
in ArcGIS Field Maps Ideas Last Updated 2 weeks ago
4 0
Open
Requested functionality:Allow users to select a start and end date/time directly in Field MapsApply dynamic filtering...
vmnblack_wsp
by vmnblack_wsp Occasional Contributor
24 0
24
Open
We are currently implementing the Field Maps application at TC Energy for our Aviation department and we need an enha...
Etiennenoumen
1 0
Open
When setting up the field maps form using field maps designer, depending on the field type the fields appearance vari...
KatieQuantrell
by KatieQuantrell Frequent Contributor
in ArcGIS Field Maps Ideas Last Updated 3 weeks ago
1 0
Open
It would be great if fields within Field Maps that are calculated via arcade expressions, could still be set to be ed...
KatieQuantrell
7 1
7
Open
Within Field Maps it would be great for the search functionality for attribute fields that use drop down lists to be ...
KatieQuantrell
3 1
Open
Would it be possible to add a Slider data entry type to Field Maps, like is available in Survey123 (https://doc.arcgi...
IngridHogle
by IngridHogle Frequent Contributor
4 0
Open
Unfortunately Field Maps is not usable for real and accurate 3D data acquisition or stakeout using precise GNSS becau...
GeoguichetGeoguichet
by GeoguichetGeoguichet Occasional Contributor
1 3
Open
This came up in conversation with one of my users the other day.It would be really useful to walk an arbitrary line a...
AlfredBaldenweck
by AlfredBaldenweck MVP Frequent Contributor MVP Frequent Contributor
1 7
Open
Scenario:You download an offline area. You go out into the field, miles and miles away from any service, 2 or 3 hours...
AlfredBaldenweck
4 0
Open
Vaguely related: Enable MMPK as a Referenced Basemap in Field Maps - Esri CommunityBackground:Well, I lost a bet with...
AlfredBaldenweck
2 0
351 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
