Now that we got filter capability for the layers in the ArcGIS Field Maps, our users are now asking: "Why can't I filter on more than one selected value at a time?"
Currently we don't see the option to select more than one value in the filter function, which is a bit of a shame, when more than one value in a code list are needed for filtering the data. The user have to go back and change between the selected values each time they want to compare and see other filtered values which is troublesome.
We have had the same request from search and rescue teams. They are very happy that they can filter now, it was the most common request, but they have a need to filter on multiple values within an attribute as suggested above. Thanks for posting this!
Yes, great function, but incomplete. Help us out ESRI!
Ditto. Hope this is an easy option to add in the next update!
This would be a super helpful feature to have!
