Filter on more than one value
4053
12
04-27-2023 01:01 AM
cbp-geus
Now that we got filter capability for the layers in the ArcGIS Field Maps, our users are now asking: "Why can't I filter on more than one selected value at a time?"
Currently we don't see the option to select more than one value in the filter function, which is a bit of a shame, when more than one value in a code list are needed for filtering the data. The user have to go back and change between the selected values each time they want to compare and see other filtered values which is troublesome.
Tags (3)
12 Comments
pjdohertygis
We have had the same request from search and rescue teams. They are very happy that they can filter now, it was the most common request, but they have a need to filter on multiple values within an attribute as suggested above. Thanks for posting this!
ZachBodenner
Yes, great function, but incomplete. Help us out ESRI!
NLewis
Ditto.  Hope this is an easy option to add in the next update!
ChristinaNeal
This would be a super helpful feature to have!
AnthonyJonesRSK
100% agree. The filtering option is a great step in the right direction but is pretty limited in its current form. It would be great to be able to apply a negative filter too. In our case we want our field staff to be able to remove any features that are set as completed. Whilst this could be a filter applied to the layer in the map settings we don't want features disappearing from the map as soon as the user updates a feature to completed. Allowing them to control what is filtered would be much preferable. It would be great to know if anyone from Esri is looking into the multiple value filters. Thanks
JTLancer
2nd that.  This was a great addition, but very limited functionality. Almost there.
ejuser
Enhancing the filter option in Field Maps Designer allowing for more than one filter selection would get alot of oohs and ahhs at the ESRI UC......just sayin:)
Emils
Habitat and species experts needs this as well when they are doing field works. "Environmental Systems Research Institute" should know that 😉
MattyMaps
Much needed
DebSF
Definitely need this please! Users often want to filter to more than one selection.
