Add the ability to set the edit capabilities for a layer in Field Maps Designer
1510
03-21-2024 12:52 PM
Status: Open
taylorrobinfemadhsgovRobin
Can there be a way to set the editing capabilities for a layer in Field Maps Designer? For example: Add, Delete, or only Edit Attributes. I know you can set this on the feature layer, but I do not own the layer and cannot make a view to set these permissions. This would be similar to the functionality in Experience Builder where you can set those specific editing capabilities in the Edit Widget. I really just want to disable deleting features in Field Maps, but adding all the options would make more sense.
2 Comments
lah
Yes, we need this! There are certain maps shared with groups that shouldn't be able to delete; however, to make this happen I would have to publish a duplicate service with those options set. Would be so much simpler and cleaner to just handle this at the map level.
LindsayRaabe_FPCWA
Seems like the next logical step for Field Maps designer functionality to me!
