Wrong filter selection on Chart Widget trigger
1424
05-24-2023 10:47 AM
RejeanLabbe
In my chart, if I click on a column, the selected result is the previous column.
In the Content tab, I selected By group as Category type and I selected the field CIV_CRI as Category field.
In the Action tab, I add a trigger to filter Data Records.
I selected both fields from the Chart and for the featureClass.
In this example, I clicked on the last column (F4 value)
The result selected column is the previous value (F3).
It seems to be an index base issue in the code behind.
I'm using Experience Builder 11.1 on ArcGIS Enterprise.
TonghuiMing
@RejeanLabbe This issue should have been resolved with the recent AGOL June release.
TonghuiMing
RejeanLabbe
Thanks @TonghuiMing I will wait for your investigation. It looks like an issue related to the the base index of the array containing values in the javascript code behind.
TonghuiMing
SarahRijneke
I'm seeing this issue in one of the experiences I've built. When I click on the yellow or brown slices the opposite features appear on the map. When I click on the green or orange slices they display as expected.
