Widget Icon Spacing - Unable to Decrease Spacing...
900
12-11-2025 10:26 AM
Lake_Country_GIS
I have a widget controller with two widgets. I would like to decrease the spacing between the widget icons.  have set spacing to "0", however, the icons are still spaced considerably. Anyone experienced this issue before?
Thanks in advance,
M
Brian_McLeer
MVP Regular Contributor
If you change your size from Large to Custom in the drop down you may be able to play with the spacing to get it to look how you want.
Lake_Country_GIS
Thanks for the tip. I must be running an older version. I don't see the custom option:
Brian_McLeer
I should have asked if you are using AGOL, Enterprise, or Developer Edition of EB. The current version of AGOL and DE 1.19 support it, I am not sure which version of Enterprise supports this, but probably 11.5 or 12.
Lake_Country_GIS
I just updgraded to 1.19. The custom setting did not help. I'll dig in and modify the widget code directly I suppose.
Brian_McLeer
The Spacing setting does not allow for negative numbers, I wonder if modifying this in the widget code would allow to reduce spacing more.
