Use selected features as input to analysis tool
14025
25
03-15-2024 06:56 AM
LarsElmkær_Chwastek
Hi all,
I have a question about using selected features in an analysis tool. I can't quite figure out how to make this work.
If I use the select tool to select let's say 10 houses from a building layer, I want to be able to take that building layer and use as an input to for instance the buffer tool..
But when I do that, it doesn't honor the selection.. it just takes all the features in the layer..
It would also be cool to be able to do the same with a GP/Web tool that you publish your self
Do anyone know a solution?
LarsElmkær_Chwastek
Thank you for the update Wei Ying, have a great weekend 🙂
GFlonk
I created a simple webtool today to test this functionality in Experience builder, and it doesn't seem to work in my case. I want to create a webtool that works with a sleection of records as input. For this I created a simple notebook with one parameter and published it as a webtool.
Then created a basic experience with just a table and the analysis widget. When i try to set the analysis tool input from the selection in the table I get this message:
When i look in the console we see this error:
Am i doing something wrong or am i encountering a bug?
DougBrowning
MVP Esteemed Contributor
No the GP widget does not respect selections at all yet.  Which is super weird to release it without that.  No one runs a tool on an entire FC.
See farther up this post there is a hack posted.
Upvote here?  https://community.esri.com/t5/arcgis-experience-builder-ideas/use-selected-features-as-input-in-anal...
Wei_Ying
The selection processing is available in ArcGIS Online, and for Enterprise, it is available in 11.4.
GFlonk
Oh yeah I didn't specify; I tried this on ArcGIS Online.
Wei_Ying
Hi @GFlonk , I guess the data you used as input is a private feature service hosted in some portal?
GFlonk
Yes it is, though my account has access to it. I think what would help here is a simple step by step doing only the necessary to verify that in experience builder; we can add a table with data, and send its selection to a webtool, then in the webtool verify we receive a selection (only by printing or something). If i have that i can verify that flow works and could be a possible solution for clients i have. I tried doing exactly this myself and ran into the error i mentioned earlier.
Wei_Ying
That's weird. I cannot reproduce based on your description. I guess it might be tool specific or data specific.
I suggest you to contact Esri Support to provide us a repro case.  Appreciated!
LisaT
Hi Everyone, I am having a lot of trouble with this and am hoping someone can point me to a tutorial? I am trying to create a simple custom tool in AGOL that will take a selection from ExB.  I am currently trying to process it as a FeatureSet. I am currently attempting to do it by selecting a default input parameter of type FeatureSet. When I add it to ExB and also add a select widget (with Set as Analysis input using "Analysis") it doesn't seem to change the "Count of Features" when I change the Selection. What should I be seeing? Is there a tutorial for either an established Analysis tool or a custom one?
DougBrowning
Correct it is ignoring the selection which was a very weird thing to leave out. It has us at a standstill on converting now.   Last I heard it was "coming soon" but I still do not see it working.
