I have been through every scenario and every product in ESRI (portal/agol, WAB/XB/Instant) and haven't figured this out yet. I thought Experience Builder would be the solution and it doesn't quite seem to be.
I'm trying to create a scenario with two different sets of filters. For example, I have days of the week and I would like the user to specify as many as they want. So I pick Monday, Tuesday, and Wednesday as 3 separate filters (in XB, under 1 filter widget). These would be an OR filter as I want all sites that are available on Mon, Tues, or Wed to show.
Then I want another filter to apply to that and be AND. So pick all the days of the week you want then add additional other filters on top. So show me sites for (Mon, Tues, OR Wed) AND that are child-friendly and have drive-thru service. Instant app sidebar template doesn't work as everything is AND or everything is OR. Even the example from the ESRI blog shows a similar LA map that has faulty filtering where the days of the week and extra features are all OR giving misleading info (https://www.esri.com/arcgis-blog/products/instant-apps/mapping/whats-new-in-instant-apps-september-2...)
I now have an Experience Builder app with two Filter Widgets and at first I thought they were working, but when I select multiple days, I feel like it switches to OR between the two widgets. If I click Senior and Monday Afternoon (from 2 different filter widgets), it shows correctly only Monday Afternoon sites with Senior service. If I add Monday Morning, it no longer works correctly. It shows all Monday AM, all Monday Afternoon, and all Senior. Not the desired result. See screenshot attachments.
Any thoughts? Please see attachments. Maybe I should move on to Query Widget? Or custom app?
Tim
Your logic appears to be sound and I have a working example of an app using two filter widgets in this way.
https://gis2.arlingtontx.gov/parkfinder/
The upper filter widget uses an OR connected and the lower filter widget has an AND connecter.
This app has been thoroughly tested and works as expected. I can't really explain your problem, but what you are trying to do should work.
That looks great. Thanks for responding.
I have a bunch of questions
I don't know if any of those questions matter, just trying to look under every rock.
See attached for my setup on Time filter.
Ok. Good to know about Developer. Thanks for your help.
Exact same setup works perfect in experience.arcgis.com. Must be some bug in Filter Widget in portal version.
