Trying to add framework filter for multiple values
746
10-08-2024 10:57 AM
WStreet
I am am working on an experience to replace some dashboards.  In the dashboards I used a spatial filter from a selection in one list to apply a filter to a second list.  My understanding in searching here is that this type of spatial filter isn't available in experience builder.  I added a condition and it works to apply a filter but I cannot make it dynamic enough.
List 1 is a list of PMs and a polygon of territory.
List 2 is a list of Projects with footprints.
I want to filter List 2 by selection in List 1.  However, the projects footprints can overlap multiple territories. So if Project A is PM ZZ's and YY's territory, if I select either one, I need to it show in Project A to show in List 2.
JeffreyThompson2
MVP Frequent Contributor
https://community.esri.com/t5/experience-builder-tips-and-tricks/using-one-datasource-to-filter-anot...
You can configure a List Widget so that it filters the data in another List Widget. It sounds like this could work in your case.
GIS Developer
City of Arlington, Texas
WStreet
Thanks. I have done that but I can only filter a single attribute from the first list to a single attribute in the second.  What I really need is in List 1, PM ZZ to filter a field containing the values "ZZ YY" in List 2?
Unless I didn't understand the linked article well enough.  I am currently doing it with a spatial filter but linking it out to a text field would be better so a supervisor elsewhere might also filter data.
JeffreyThompson2
Yes, I think it would have to be a simple one-to-one correlation to make that kind of filter work.
If you have access to the Select Widget, maybe you can do something with the Spatial Selection option in there.
https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/select-widget.htm
GIS Developer
WStreet
I could set it up in a one-to-one way.  Just every time it happens I have to generate multiple features for the same thing.  Then I am increasing my storage on AGOL as well.  I am trying to make it as simple as I can.
