Using output of Create Watersheds Tool as selecting layer in Select widget
584
10-08-2024 11:14 AM
MikeWallaceDWR
I'm trying to build a simple application where a user can add a pour point, create/delineate watershed(s) with the Create Watershed in Spatial Analysis tools, then select points from a different layer that are within the created watershed polygon output. This can be done using the "Find by Attributes and Location" in Spatial Analysis Tools, but it requires credits. Is there a way I'm missing to configure the Select tool for this? Or is that a different widget that could accomplish this? The Create Watersheds outputs can be added to map and interacted with via other widgets, but cannot be chosen a selecting layer when configuring the Select widget, because that layer hasn't been created yet. I imagine there's some way to accomplish this on the developer side, but hoping to have a simpler path. Thanks!
