Selection in chart not zooming to features in map?
2696
13
03-21-2022 01:30 PM
Hayley
Hi there,
I would like my chart to filter, select and zoom to selected features in the map. At the moment it selects and filters but does not zoom to the features.
This is how my chart actions are set up
And this is the map
Any pointers would be greatly appreciated thanks 🙂
HL
TonghuiMing
Hi @Hayley and @Ashok,
I dug for a while and found that this should be a known limitation at this moment. For W-Chart & W-Map interactions, there are only Flash and Filter supported. It appears that the options of "Zoom" and "Pan" in the Chart widget were not removed from the UI so it is documented here: ExB Chart widget > interaction options note
For this function itself -
From my understanding, unlike the Query widget, which directly utilizes the added data source, Chart creates an output data source (i.e. Chart statistics) right when data gets rendered. Once that happens, it lost all geospatial reference, thus, there is no way to get the extent for zoom or pan which depends on geometry, when you select anything from the Chart widget.
Ashok
I am also facing similar issue. Not able to zoom to feature, where as I can able to do select, flash.
Do you have any further update/enhancement on your post. If you have any success, please share.
Ashok
Hayley
Hi Ashok, I spoke to an Esri consultant and they were quite certain that it is not possible as there is no "geometric values" in the statistical chart?
HL
Ashok
But we are able to select/flash the feature on Select Data Records Trigger/Action.
Then why we are not able to zoom to feature.
Can any ESRI people respond on this. Or please let us know if it can be implemented in future releases.
Because it is very common functionality that any user can look for zoom to feature on bar chart item click.
Ashok
Hayley
Yes that's what I thought, can someone from Esri please touch base on this?
HL
TonghuiMing
Hayley
Thanks for your response! I hope there is a workaround this in the near future as it is a major setback.
HL
TonghuiMing
We will look into that and see if there will be any enhancement possibilities.
ScottHansen__MDP_
I too would like to have the ability to select features in a chart and have the map pan and zoom. After talking with ESRI support, I have learned that this is a known limitation and that an enhancement case has been opened: ENH-000151058 Chart: support geometry-related message actions like zoom/pan to. Experience Builder = work in progress.
JanetSilb_Spike
@ScottHansen__MDP_ do you know if there is any progress on this enhancement request?  I am also looking for the ability to zoom to features from the chart widget.  thanks!
Janet Silbernagel, PhD, ASLA, SITES AP, WBE
Silvernail Studio for Geodesign, LLC
https://www.linkedin.com/in/jsilb/
