Does the Query widget allow for add to selection and remove from selection?
cheers
Rod
Thanks for the post! I think the Select widget is a better fit. Please refer to the documentation below.
https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/select-widget.htm
Hi @RodWoodford
I believe that with the Query Widget every time you want add or remove from the selection you will need to redraw/select and reapply the new input to get your result.
I have found the following community post which may prove useful in this instance.
