Query Widget - Add to Selection
1230
03-20-2024 04:06 AM
RodWoodford
Does the Query widget allow for add to selection and remove from selection?
cheers
Rod
DanielFox1
Hi @RodWoodford
I believe that with the Query Widget every time you want add or remove from the selection you will need to redraw/select and reapply the new input to get your result.
I have found the following community post which may prove useful in this instance.
https://community.esri.com/t5/arcgis-experience-builder-questions/experience-builder-query-widget-re...
TianWen
Thanks for the post! I think the Select widget is a better fit. Please refer to the documentation below.
https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/select-widget.htm
RodWoodford
Hi
The select widget is not the answer to non spatial queries. The query widget  allows users to build non spatial queries, it needs an add to selection and remove from selection function to assist in refining attribute queries that return a spatial and non spatial result.
cheers
