Passing Query Widget Output as URL Parameter
2182
6
09-15-2022 08:34 AM
sealeg
Is it possible to pass a Query Widget output as a URL parameter? When I try, the page begins to load with the parameter as part of the URL, but then removes the parameter and loads the default page.
Example:
This:
https://experience.arcgis.com/experience/ad6e0b92d98e4ced94e17c6aec25bda4/?data_id=widget_33_output_44548751669035913%3A8
Defaults to this:
TianWen
The sample app is not accessible. Could you check the sharing setting and then we'll take a look? Thanks!
sealeg
It is shared now. Thank you. Try querying a  PIN like 130520.00. You will see when you select the query result it passes the parameter to the URL, but if you try to load that URL in a new window, it reverts back to the default URL.
TianWen
The case is not currently supported. For Query widget, you may need to apply it to get the output, otherwise, the "selection" parameter in the URL will be removed.
sealeg
What do you mean by "apply it"?
TianWen
That means triggering the apply button.
sealeg
I want to send a URL to another user with the query result as a URL parameter. It seems that this is not possible. I don't think apply button has anything to do with it. I can apply on my side and the URL shows the query output. If I copy that URL and send to someone else (or open a new window), the page does not load the query. I decided to go another route since this does not seem possible. Thank you for your help.
