Is it possible to pass a Query Widget output as a URL parameter? When I try, the page begins to load with the parameter as part of the URL, but then removes the parameter and loads the default page.
Example:
This:
https://experience.arcgis.com/experience/ad6e0b92d98e4ced94e17c6aec25bda4/?data_id=widget_33_output_44548751669035913%3A8
Defaults to this:
The sample app is not accessible. Could you check the sharing setting and then we'll take a look? Thanks!
It is shared now. Thank you. Try querying a PIN like 130520.00. You will see when you select the query result it passes the parameter to the URL, but if you try to load that URL in a new window, it reverts back to the default URL.
The case is not currently supported. For Query widget, you may need to apply it to get the output, otherwise, the "selection" parameter in the URL will be removed.
What do you mean by "apply it"?
