New Batch Editor functionality doesn't work for calculated fields
2405
10
07-04-2025 02:55 AM
StuartMoore
i've just tried the new "Batch Editor" functionality it seems to calculate the values in the form but it doesn't save them against the data and only saves the values you manually update.
the below example the outcome / high level outcome & status fields are all calculated based on the questions above and the comments field is manually entered
after pressing update and viewing the data in the popup it shows the comments populated but all of the calculated columns are blank
HeatherGonzago
Hi everyone, we addressed this issue in a patch. We should have it out later today. You should be able to pick it up and see the changes by tomorrow.
Thank you for letting us know so we could take care of it quickly.
LindsayRaabe_FPCWA
MVP Regular Contributor
Confirmed - I'm seeing the same behaviour. Very disappointing! Thought I was clear free when I saw that it was honouring the calculated Required and Visibility conditions, but alas, one search to find if there were others finding issues, and here we are.
Also discovered in testing this issue, that if you have features with differing values in a field, it correctly returns the (Different values) statement in that field if it's a normal field, but not for Calculated fields. Something else that should be considered.
Time to disable again.
@AlixVezina
Lindsay Raabe
GIS Officer
Forest Products Commission WA
HeatherGonzago
Thanks for the info, we are currently investigating this and will keep you updated on any updates as soon as possible.
- Heather
LindsayRaabe_FPCWA
Thanks for the update @HeatherGonzago
Lindsay Raabe
GIS Officer
HeatherGonzago
Hi, in addition to the original question. You mentioned
Could you clarify exactly what you are seeing? This could be something that may potentially need to be addressed.
LindsayRaabe_FPCWA
If I had selected 2 features created by 2 different people with their names stored via a calculation, unlike a normal field, it doesn't show the "Differing values" line. It just calculates with the new value straight over the top (I imagine this is expected behaviour). Though, as per the "Differing values" functionality in Batch Attribute editing, it would be good to optionally have that field update or preserve the original (differing) values (maybe a button appears for each calculated field which refreshes calculations when being used by a Batch Edit Widget).
Lindsay Raabe
GIS Officer
HeatherGonzago
Tiff
Hello @HeatherGonzago thanks for this as calculated fields are extremely important for our data editing workflows!
However today I'm noticing this error on a batch edit attempt, relating specifically to calculations. Happens to at least two layers. Could you support or advise? It was working fine a couple months ago, but I wonder if it's due to the October AGOL update.
HeatherGonzago
@tif
Could you provide more details as to what you are doing within your form and what your expression is doing? What type of data are you using? The more info you can provide,  the better.
Thanks
Tiff
Hi @HeatherGonzago false alarm, sorry! There was an issue with a layer that the calculations relied on, which caused the calculations to fail. It's been fixed, thankfully!
