https://localhost:3001 no longer supported with ArcGIS Online
13847
12
12-03-2021 10:41 AM
PeterKnoop
MVP Regular Contributor
It seems that ArcGIS Online no longer permits you to use "localhost" as an Allowed Origin for CORS. So you cannot set https://localhost:3001 as an Allowed Origin, as required by Experience Builder.
The instructions in ArcGIS Experience Builder install, therefore, no longer work. When you get to Step #8 under "Create Client ID using ArcGIS Online or ArcGIS Enterprise", you cannot get past the error message, "Your application domain is not allowed via Cross-Origin Resource Sharing (CORS)..."
Instead of localhost, one has to set the fully-qualified domain name of their computer (e.g., http://mycomputer.mydomain:3001) as an Allowed Origin on your ArcGIS Online instance, and use it in place of https://localhost:3001 everywhere in the Experience Builder instructions.
Do the instructions need updating, or is there an easy way around this that I am missing?
PeterKnoop
@awgeezrick we ended up getting real SSL certs for our development machines, and ensuring their domains were added to the "Allow origins" list in ArcGIS Online settings.
awgeezrick
Thanks for the info, I ended up doing the same thing an all is good now.
Thanks again.
Mark
boro
Running into this issue too... Literally no idea how I can continue from here... This is so frustrating, update the guide or just remove it for crying out loud
