Hide time in Table widget
12462
35
02-16-2022 09:47 AM
AmyRoust
I'm using the Table widget in Experience Builder (the online version, not developer edition). My date fields are displaying the time, and I'm wondering if there is a way to hide that? Time is irrelevant for this dataset - they just need to track the date.
Tags (3)
Tiff
Hey @AmyRoust, I went through the same motions as you. With anything new that is released by Esri, I always err on the side of caution. I have a feature layer with nearly a dozen date fields that I was excited to try it for.
I decided to try it for another layer that only had one date field and immediately realized it wouldn't work. Not only that, adding the date only field seemed to alter my projection for some reason, which then caused another issue in the AGOL environment (can't remember what exactly, but it was a whole ton of hoops to jump through just to try one change). Hopefully it was an easier time for you!
vshrinivasan_gispes
Do we know when this bug will be fixed?  This has been an ongoing issue for quite some time now
lesliecsy
It’s 2025 now 😢
Friendly reminder: Never change the data type to Date Only. That type of data won’t display on Experience Builder.
AlessioDiLorenzo
Same situation here:
I don't need the time but there's no way to get rid of it.
This could be a minor thing for someone, but is very important to my users and I can't use ExB in production if the date field contains the time component!
Please, fix it
RachelS
Also looking for an update on this.
Can anyone tell me where to enter the ENH-000135112 that was logged for this to get an update?
If I enter it into the ESRI support page nothing returns, adding it to google doesn't return the details either. Surely giving out the enhancement number should allow users to obtain an update or am I missing something?
HanRit
With Esri retiring Classic in Q1 2026, there really needs to be a fix to this.
