I'm using the Table widget in Experience Builder (the online version, not developer edition). My date fields are displaying the time, and I'm wondering if there is a way to hide that? Time is irrelevant for this dataset - they just need to track the date.
I just checked the site that I had the issue on - the table is still displaying times and I don't see a button to suppress that or honor the SmartForms settings. As far as I know, this enhancement has not been implemented.
Hi @CassNEGIS , This bug needs to be fixed from the API side, you can follow support issue ENH-000135112.
Hi @AmyRoust ,
You can hide fields in the table widget settings.
Uncheck unnecessary fields to hide them at runtime.
Regards,
Shengdi
@ShengdiZhang - that won't resolve my problem. I'm asking about hiding the time in a date/time field. I don't want to hide the entire field, but rather just the time. (See screenshot in original post.)
@AmyRoust Sorry, I misunderstood your question.
If you just want to hide the time but keep the date, you can open your map in the new Map Viewer.
Select the layer, click on "Configure fields", and then select the field Last Invoice Date. Disable the "Show time" option, and you can see that only a date remains in the field.
Thank you, @ShengdiZhang . Unfortunately, the table widget in Experience Builder does not honor that setting. I already have the time suppressed in the Map Viewer, but it still displays in the table widget.
Hello @ShengdiZhang I wanted to follow up on this question. As @AmyRoust mentioned the Experience Builder table widget does not reflect the settings in Map Viewer. The time still shows but we would like to be able to hide it in the table.
Glad to see I am not the only person having this issue. Looks like you found it a few years before me though. Has ESRI reached out on how to get around this?? Curious what worked for others...
Looking at the thread- I dont see a solution though.
Is there any word on updating Experience Builder so date fields can be set to not show the time in Experience Builder?
@ShengdiZhang when this is fixed, could you please notify us through this thread? Thank you!
