Experience Builder Feature Info for Multiple Layers
25829
47
07-08-2020 12:47 PM
ChristopherEby2
I have a web map with 13 layers. I'd like my experience builder app to have a side bar with a Feature Info widget that changes to show the details of the selected feature no matter which feature is selected. Is there a way to do this?
Right now I can only see how to associate a Feature Info widget with a single layer. I don't see a way to show or hide widgets based on selections so I can't create a Feature Widget for each layer and show them when their respective layer is selected.
wliu
Do you have any idea when this update will be in the release? @Wei_Ying
Wei_Ying
@wliu which feature do you mean?
KGalluccio
Do you know when this enhancement to the FeatureInfo widget will be released?  Specifically clicking on the map and it showing all layers that are visible instead of only the topmost layer?
TimWestern
MVP Regular Contributor
One option might be to code a custom widget.  It can then query all the different features (even if they are in separate layers) and then based upon that give you a pageable list of the features to view could be displayed in it.  The original post suggested 13 layers, so you could use a geometry query to get either a centroid, or a map click to query beneath, and whatever intersects could then be returned as possible data to view that way.
Wei_Ying
It is on our road map to improve the UX of FeatureInfo.
The current workaround is maybe use the popup in Map widget, but choose to Dock the popup to side.
SaraFrankenfeld
I would also love to know when this enhancement will be available. I feel like the docked popups do not look very good for our app.
SmannCON
Has there been any progress on this?
abureaux
MVP Frequent Contributor
This should already be completed/released. Depending on what version of EB you are using, just ensure it is included in that version. E.g., EB can be included in AGO (I believe this gets regular updates), Enterprise (stuck with whatever version shipped with your current build), or the stand-alone Developer version (you can update this one yourself. Best option IMO).
