Feature Info Widget displays no data after moving to different section
607
01-29-2025 08:39 AM
CameronLacelle
In Experience Builder, I've created an app that has a section widget containing three sections: an interactive map, a feature info, and another feature info. I have a views navigation to go between these views but ultimately the first page is the map.
I noticed that when I refresh the ExB page and I am on one of the feature info widget sections, the refresh will remain on that section view (I guess you can't make it default to the interactive map section). Once refreshed the feature info widget appears fine but as soon as I navigate to the interactive map and then back to the feature info widget, it displays no data until I refresh the page again. If I start on the interactive map page on first refresh and navigate the views this does not happen.
Just wondering if anyone else has come across this and knows of an easy solution or if this should be submitted as a bug to esri.
Wei_Ying
Thanks for your feedback! Are you working with ArcGIS Online or Enterprise?
Would you be able to share your application for investigation?
Wei
