Edit Widget - How to set up for editing for related tables
5596
03-02-2024 01:02 PM
LJackson29
Hello -
I am using Experience Builder in ArcGIS online and have a parent hosted feature layer (Asset) with a related table of inspections. I have set up the pop-up and a form in map viewer to include the related table and I can edit the related table when editing the parent feature layer in map viewer, but I can't figure out how to set it up the Edit widget in Experience Builder to do the same. I thought editing related tables was added to EB last fall. Can anyone explain to me how to implement this. I have looked through documentation but it is very sparse.
Many thanks!
Leila
ChristopherCounsell
MVP Frequent Contributor
Here is a guide on how to do it:
https://community.esri.com/t5/experience-builder-tips-and-tricks/setting-up-a-related-table-for-data...
If it's working in the map viewer, and that map is driving the edit widget in the Experience, just double check that the widget is configured to allow both geometry and attribute updates. This is a requirement
https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/edit-widget.htm
LISARAYBURGodot
I do not have the option to add related records in the form builder from Map Viewer. I am using published services, would this matter? The example is showing hosted feature layer. This has been a huge problem because I need to be able to edit related records and do not want to keep building in web app builder.
