"Publish" button intermittently greyed out
4470
7
06-18-2024 04:46 PM
ChrisH2
ExB (not the developer edition)  in Enterprise 11.2
I have an intermittent issue where the "Publish" button is greyed out  / disabled preventing me from publishing. There are no other errors or issues with ExB and I can successfully run it in preview mode, but cannot publish until I "Save As" a new item (the only workaround that I can find).
The only thing that I suspect is a trigger for this is that from time to time, widgets such as Filter and Query will loose their Map connections and the "Select data" command within the widget config doesn't load the underlying Map or data layers. . A "Save As" will also fix this issue
This has been a manageable issue while this app has been in development, but the continual changes in item ID's with each "Save As" is becoming a hassle.
Wondering if anyone else is experiencing this issue or has a known fix
RichardSyme1
Hi Chris, we're also experiencing this issue in our organisation. We are on Enterprise 11.2 also. Our team members are doing a Save As but this doesn't seem to fix the issue. Have you been able to resolve? I'm wondering if this is a bug and if ESRI need to be notified.
ChrisH2
Hi Richard, this is still a persistent problem for us. I think you're correct and I'll look to log it with ESRI formally
ArianaMo1912
I have the same problem! Were you able to resolve it by chance?
ChrisH2
Hi @ArianaMo1912 , no it still persists and I haven't been able to find a trigger for it
Galen_S_MnDOT
This just happened to me in Experience Builder on ArcGIS Online.
**UPDATE, about ten minutes later** Publish button is back!
Weird, I don't THINK I did anything to trigger its reappearance.  Simply reloaded my browser tab with the app editor open, and walked away for about ten minutes.
KatClifton
This is still an issue in Enterprise 11.3. I have found that sometimes the Publish button will appear after I have saved the Experience Builder application following a browser refresh. This does not work all the time, but has worked some of the time.
YRP_GIS
I'm in Enterprise 11.4 and have just had this happen to me for the first time. Has anyone had this recorded as a bug at all?
