Draw Widget: change style of finished drawings
1060
6
03-08-2024 03:53 AM
DirkSilbermann
When polygons or lines are drawn using the "Draw Widget" in Experience Builder: How can I change coloures once drawing is finished?
I can only choose styles before i draw something, not after drawing is finished. If I select drawings, I can only doublicate, delete or change shapes, but not change styles like colours.
Usually changes in Styles happen after something is drawn, to adjust its look with the map, or in my case 3D scenes...
Or am I missing something?
Shen_Zhang
Hi @DirkSilbermann
I'm afraid there is no way to change the symbol of the finished drawings for now. But I think this is a good point to enhance. Please feel free to raise an idea or contact Esri support to create an issue, so we can take if from there and evaluate the issue priority along the way. Thank you!
Shen Zhang
JeffreyThompson2
MVP Frequent Contributor
Re-designed Draw widget - Esri Community
If you are on Developer Edition, the @RobertScheitlin__GISP Draw Widget supports changing styles after drawing as well as adding text. I don't know if it will work in 3D.
GIS Developer
City of Arlington, Texas
FredericPoliart_EsriAU
Also if the latest Draw widget is nested inside a Section/View,  and the admin configured to "toolbar", then the Draw pop-down rectangle stays floating on top , even if we toggle to another Section view .
Shen_Zhang
@FredericPoliart_EsriAU Thanks for reporting, we will take care of it.
Shen Zhang
DanCopKac
Hi @Shen_Zhang, before you guys work on adding any new features to the draw widget, can you please tell me how to label my drawings? Or otherwise add that feature, which is WAAAAAAAAAAAAAYYYYYYYYY more critical than changing the colour of drawings after the fact?
jhobb
The ability to change symbology after creating a drawing would be valuable to our users as well.
