Copy Features Function Missing from Experience Builder Edit Widget
20321
55
09-19-2023 08:55 AM
JeremyBrown4
I have been searching the community site for a while looking for an answer to this question, but every time I see it asked there is no response from ESRI. I will go ahead and @AlixVezina , since she wrote the last article I read on the new Edit widget in ExB.
My question is, are there any plans to updated the new Edit widget in ExB to include the Copy Features functionality that the WAB version currently has? If not, will there be some combination of features or Arcade functionality to accomplish this task, or will it simply be unavailable in ExB?
3 Solutions
AlixVezina
Hi all - quick update on this. Work is in progress and the target for copy and paste in Experience Builder is the next release (February/March timeframe). The functionality should be the same / very similar to what you'll find in the Web Editor right now.
AlixVezina
Copy and Paste in now available in Experience Builder in ArcGIS Online. You can find it in the Edit widget, when using "Interact with a Map widget" Mode. The option is at the bottom of the Content panel, as part of the Advanced editing tools.
AlixVezina
@SDIGITAFB Copying features from non-editable reference layers in the map is supported.
Here's a sample you can try out: Create Evacuation Zones
The web map contains the USA ZIP Code Boundaries (a non-editable reference feature layer), along with the Evacuations editable hosted feature layer that you can paste into.
Since the reference layer is not editable, you'll need to use other selection tools than the one included with the Edit widget to select the features to copy. For example, you can use the Select tool in the Map widget.
You can also use the Add Data widget to add layers to the map use copy features from those layers to paste into your editable layers.
AlixVezina
Hi @JeremyBrown4 , Thanks for posting your question.
We have plans to provide this functionality in the future, but the delivery timeline has not yet been determined.  We're hoping to get this into our products in time before the ArcGIS Online retirement of Web AppBuilder at the end of 2025.
Right now, if you're looking to copy one feature at a time, there is an available workaround using the Survey widget in Experience Builder:
Using Experience Builder and Survey123 to pass attributes and geometry from one layer to another (es...
JeremyBrown4
That's great news! Thank you for the quick response! I totally forgot about that new feature of the Survey widget in ExB. I am going to see if I can make that fit my workflow. Thanks again!
KatieHansen_NIFCAdmin
Hi @AlixVezina ,
I'd like to tag onto this question with something more specific. I have users that would like to add a polygon from a shapefile to an existing hosted feature service. Our workflow now it to use the Add Data widget in WAB to add a shapefile and then Smart Editor copy feature into our HFS. Is this possible in EB yet? Is there another creative way to use S123 in EB to copy this shapefile?
Thanks!
Katie
AlixVezina
@KatieHansen_NIFCAdmin
The Survey workflow described in this blog will not work with temporary data added to the map using the Add Data widget since the connection between the source and target layers needs to be set from within the Survey widget configuration.
This is definitely a valid request and in line with what we had in the Web AppBuilder Smart Editor, so thank you for bringing it up!
Thanks very much, @AlixVezina , for the reply.
Can you speak to whether this functionality is on the EB roadmap or, if it specifically is not, then will there be thoughts to a work around like the one mentioned above with the use of S123 to add features?
We would really like to have our users add new and edit existing features via an app into our authoritative, national datasets no matter how the features were initially collected but seems that we are firmly planted in WAB still.
Thanks!
AlixVezina
This functionality is currently being researched and planned. We don't have any details yet, but once we do I'll make sure to provide an update. Since this was a popular workflow in WAB, it will make sense to also support it in Experience Builder.
SusanPollard
Add data (file) and copy feature (smart editor) is one of our most used workflows and a showstopper for experience builder. The comparison functional matrix below
is misleading in suggesting that smart editor is in any way equivalent to EB 'edit' widget. There is no comparison. Web AppBuilder and Experience Builder functionality matrix—ArcGIS Web AppBuilder | Documentation
Tiff
Hello @AlixVezina thank you for this temporary solution. Can you provide more detail on guidance and best practices to set this embedded survey up? In order to copy a feature from one layer to an existing layer, does it require Survey123 Connect with the same calculations/configuration as you would in a typical survey? It would be helpful to have steps that one would take to ensure that this works properly as part of the ExB widget.
JaredDoke
We use the Smart Editor Widget copy features functionality in a few of our core workflows for Urban Search & Rescue. See this video here https://screenpal.com/watch/c0iYh1Vkezl. We had planned to move over to Experience Builder for our 'Intel Manager', but are stuck on Web AppBuilder until Copy Features is a capability in ExB.
