Can the list widget return to default extent when item is unselected
6733
12
10-17-2022 09:48 AM
BaileyBellavance
I am working on an Experience that uses a list widget to show property points on the map, and you can select one of those places and the map will zoom to that location. I have it configured so you can click on a More Info button that takes you to the feature info, or you can simply unselect it if you only wanted to zoom into the location. I currently have this as a message action when the record selection changes in the list.
I've been trying but haven't had much luck in figuring out that if someone were to unselect the location from the list, can the map then automatically zoom out to it's default extent? This would greatly improve the functionality of my app as I'm basically recreating a Short List Story map into experience builder.
Thanks!
Nora-Schaak
Fantastic! This is so great to see. Thank you Ke_Xu!
LouLambe
This does not seem to be available in Enterprise Version of Experience Builder! 😦  The Setting in AGO has not yet made it to Enterprize Portal.The Setting in AGO has not yet made it to Enterprize Portal.
Ke_Xu
by Esri Regular Contributor
Hi @LouLambe,
This feature was released on ArcGIS Online in November 2024. It will be released in the upcoming Enterprise 11.5(at the end of May).
You could also use ArcGIS Experience Builder Developer Edition 1.16 with your current Enterprise version.
Ke
