Batch editing in Experience Builder
8886
12
07-18-2022 10:41 AM
DianaL
Hi, since the batch attribute editor widget is not available in Experience Builder yet, does anyone know if its possible/how to bring WAB's batch editor into ExB as a custom widget, or another workaround?
@Jianxia
Thank you!
LindsayRaabe_FPCWA
MVP Regular Contributor
Early 2025 now - Really looking forward to shutting down our old WAB Apps so I'm not running parallel apps!
Lindsay Raabe
GIS Officer
Forest Products Commission WA
sondickerson
@Jianxia  When developing the Batch Editor for Experience Builder, please have the team test it with postgresql versioned data.  The App Builder batch editor inconsistently works with versioned postgresql, usually producing errors with the layers :  The requested operation is invalid on a closed state.
Once the errors take place, it eventually causes issues with rendering the service .   We have a support case for this:  Esri Case #03493927 and it would be good to review it, if that's possible.
Thank you so much for all of the good work you are doing.
AlixVezina
Batch editing is now available in the Edit widget when using "Interact with a Map widget" mode, in Experience Builder in ArcGIS Online. Enable the option in the General settings.
Batch editing will also be made available in "Attribute only" mode in a later release.
