Arcade Data Expressions in Dashboard to Experience Builder
7217
07-31-2023 09:50 AM
M_M
I created an arcade data expression in Dashboard to return a FeatureSet with a couple new fields to be used in Indicators.  Is there any way to duplicate the FeatureSet result in Experience Builder?
I’m running into an issue with replicating the filters I created in Dashboard using a data expression to use in Experience Builder.
  • I created a Dashboard to show data errors via Indicators.
    • I needed to use a data expression for some of the indicators as I was missing some fields needed in my filters or needed to access attributes in a related table (ex. I have ‘Age’ attribute but needed ‘Year Planted’ attribute.)
  • User wants to be able to view and edit the records with errors that are indicated in DB. I embedded the Dashboard into Experience Builder.
  • I then used Filters in Experience Builder along with a list & edit widget.  User applies filter to display records with errors in a list and map, and are then able to edit errors right away.
  • This all works as planned until I get to the Dashboard Indicators that use a data expression. I can’t recreate the DB filters in Experience Builder.
Any suggestions?
ZenMasterZeke
ExB is very limited on the types of expressions you can create. It doesn't support Arcade 😤. This is a highly requested capability, but who knows if/when it'll be implemented.
ZenMasterZeke
M_M
Ugh-not the answer I was hoping for, but thank you for letting me know!! I appreciate it!
andeb31
It appears this functionality was released in June 2025, however some users are noting limitations. Check out this thread for more info https://community.esri.com/t5/arcgis-experience-builder-ideas/allow-arcade-expressions-in-experience...
I have also been looking for this functionality, along with the "Group By" ability in the Dashboard table widget that allows for summary statistics. Seems like at least the data expression piece may now be doable in ExB.
