Support for Image Service in Experience builder Timeline widget
4673
6
01-20-2023 04:35 AM
Status: Open
Labels (2)
Sil_
My idea is for the Timeline widget in Experience builder to support Image Service as a data source. The Timeline widget currently supports map services, but not Image service. If I try I get the message "No added data can be used. Please add data."
The Time slider in Instant app (Slider template) and in Time slider widget in Web AppBuilder handles the Image service without any issues.
In my case it would enable me to use an Image service with historical aerial photos together with a time slider, which in Experience builder would be used to compare older and newer situations with two maps (connected by trigger+action when extent changes) side by side. Currently, I would have to embed the Instant app, but it will have no connection to the other maps and functions in Experience builder.
6 Comments
TilmannSteinmetz2
I think this is a great idea - although I would hasten to add that Image Services should get support in Experience Builder in general, for instance by adding a widget that allows a user to change the rendering options or filter for certain attributes in a multidimensional image service. Currently this can only be done in the MapViewer - typically by a GIS analyst or admin. There is no method at all for end users to control what or how an Image Service is displayed unless they make their own web map.
I have submitted that idea as https://community.esri.com/t5/arcgis-experience-builder-ideas/expb-working-with-image-services/idi-p...
MichaelBell
We'd need this too, for accessing the Sentinel-2 service. I'm currently trying (and failing) to hack away at the service through widgets and console logging to get to the acquisition date, so a dedicated way of using a timeline would be great.
Have upvoted the idea.
DougBrowning
Need it also.  Anyone know what it does work with?  Tested WMS, layers, and a Mosaic dataset all no go.  WAB and map viewer and Pro it all works.  How can this widget even be used?  Thanks
Marshal
Great idea!  My organization needs this as well.  We would really like to get away from using Instant Apps instead of Experience Builder, but have little choice due to this deficiency in Timeline widget.
Jianxia
Thanks for sharing. Support for raster data source (Image layers) in Experience Builder is planned for the upcoming June release of Experience Builder in ArcGIS Online. In addition to displaying them in the Map widget, you should be able to interact with image layers with other widgets such as Table, List, Timeline, etc.
Marshal
@Jianxia
After testing in ExB 1.15, it appears only image layers with "field information" are supported by the Timeline widget.  In my workflow, publishing a multidimensional .crf as image layer is not supported because it is not published with fields info.  My understanding of the solution, which I admit is somewhat limited, indicates that only image layers published from mosaic datasets will be supported as they are published with the fields info required by the widget.  Publishing mosaic datasets requires an ArcGIS Image Server license.
Perhaps there is a workaround for this I am missing?
The Time Slider Instant App does support image layers without "field information", so users with similar workflows will still be limited to Instant App.  I hope this functionality can be matched in the ExB Timeline widget.
