Filter widget - Allow a default SQL expression when filter is off
992
09-29-2023 06:44 AM
Status: Open
OlivierJobin
I'd like to have a default SQL expression to be applied when a toggle filter is "turned off".
The idea is to be able to use a toggle as a kind of before/after button so that the user can switch between two filters with a single button.
For the before/after scenario, applying two toggles (one before and one after) is not very optimal since the user needs to do at least two clicks.
Thanks !
1 Comment
JeffreyThompson2
This logic could work for you. Depending on what exactly you need your filters to do.
https://community.esri.com/t5/arcgis-experience-builder-questions/overwrite-default-map-filter/m-p/1...
